logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Jeep
4x4Community
Reply
Thread Tools Display Modes
  #1
Old 02-06-09, 09:06 PM
Dirk's Avatar
Dirk Dirk is offline
Administrator
Default Disabling chimes
Jeep Wrangler JK - 2007 onwards
Disabling seat belt chime.
Here are the steps to deactivate the chime.
1. Turn the ignition switch to the OFF position, and buckle the driver or front passenger seat belt.
2. Turn the ignition key to the ACCESSORY/RUN position (engine does not need to be running), and wait for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle and then re-buckle the driver or front passenger seat belt at least three times within 10 seconds, ending with the seat belt buckled.
4. Turn the ignition key to the OFF position. A single chime will sound to signify that you have successfully completed the programming.
__________________
DASHCAMS AVAILABLE IN THE ONLINE SHOP![/U][/B]
R1995.00 including courier delivery and Micro32gig SD card.
EFT and Credit Card payments available.
Click here to purchase.
2016 National GTG
Ruby River Resort, Groblersdal
All the info, CLICK HERE!
  #2
Old 02-06-09, 09:08 PM
Dirk's Avatar
Administrator
That's the one I did not really need, looking for the key in the ignition, door open, car not started, foot on the floor, lights are on, lights are off, start, stop etc, ie all the other chimes!
Please post if you have the details. (For all the Jeep models)
Thread sticky.
__________________
2016 National GTG
  #3
Old 03-06-09, 03:32 PM
bushcamp's Avatar
bushcamp bushcamp is offline
Member
Just remember that the buckle status determines the airbag deployment functionality as well.
  #4
Old 03-06-09, 07:07 PM
Uys's Avatar
Uys Uys is offline
Commercial Member: Stofpad Products
A friend tried it on her 2007 Cherokee and it also worked.
__________________
Overkill - isn't!
uys@stofpad4x4.co.za
www.stofpad4x4.co.za
Why you need Stofpad4x4 Rock sliders
Office: 012 654 7723 (sales)
  #5
Old 03-06-09, 08:01 PM
Biggles's Avatar
Biggles Biggles is offline
Member
Default Grand cherokee
Disclaimer: Who's responsable, you did it
First remove covers around steering wheel. Note that the upper 2 screws need a T25 torque key.
This image has been resized. Click this bar to view the full image. The original image is sized 750x600 and weights 72KB.
Next on the left hand side you will see the actual switch that drives the ignition.
This image has been resized. Click this bar to view the full image. The original image is sized 750x600 and weights 73KB.
Here is the mechanical part. See the buzzer is hard wired to the ignition via a pressure switch. (just as I thought, Benhur right on the money ) Shaft pushes out when key is insetted. EDIT: Switch also wires to the computer
This image has been resized. Click this bar to view the full image. The original image is sized 750x600 and weights 63KB.
Next pic the actual switch notice 2 plugs. Small one for the buzzer, big one for the ignition wires. Rond bit the actual pressure switch.
This image has been resized. Click this bar to view the full image. The original image is sized 750x600 and weights 58KB.
Here is the plug for the buzzer halfway removed it has a blue and black wire.
This image has been resized. Click this bar to view the full image. The original image is sized 750x600 and weights 83KB.
Now with that done I think that the hachets, nail files and angle grinders can leave the buzzer alone.
EDIT: NOTICE when removing the plug, two functions are lost in the overhead display (Remote linked to seats and easy exit seats) Only realised this when I had to set it for my mother (yes she also drives the Jeep). I don't use the functions. I'm 6'1" mom is 5' somewhere short
Easy exit seat is totally lost as it cannot read when the key is removed. The memory linked to remote still functions, but it has to be set before the plug is removed.
No codes show up when the plug is removed, strangely
YOU HAVE BEEN WARNED.
Hope this helps for other people that want to rip open the dash and smash the buzzer to smithereens.
__________________
2002 Nissan Patrol 4.2Td. Body lift, 5cm OME lift 33inch Cooper SST, Burnco bumpers.
Platkar:2002 BMW M5, 2002 M Coupe and 1985 635csi
SWAMBO: BMW X5 3.0D
Talk softly, carry a BIG stick
Ex: Jeep Cherokee XJ 2.5Td
  #6
Old 07-06-09, 08:19 PM
HennieZJ's Avatar
HennieZJ HennieZJ is offline
Member
Biggles you forgot to tell Dirk the part where the warning also tells you.....DON'T TRY THIS AT HOME!!!!!!!!!!!
__________________
It's a J e e p thing...........you would'nt understand!!
Ek ry met stok-ou Jeeps, want dan dink almal ek's al lankal ryk!!
Gee vir my 'n Coke......skoon Coke......met 'n dubbel Brannas in asseblief!!
  #7
Old 01-07-09, 09:18 PM
domino16261
Guest
Posts: n/a
Question
Quote:
Originally Posted by dirk View Post
jeep wrangler jk - 2007 onwards
disabling seat belt chime.
1. Turn the ignition switch to the off position, and buckle the driver or front passenger seat belt.
2. Turn the ignition key to the accessory/run position (engine does not need to be running), and wait for the seat belt warning light to turn off.
4. Turn the ignition key to the off position. A single chime will sound to signify that you have successfully completed the programming.
this worked on my 2005 cherokee, hows do you enable it again as this effects the airbg function as well/ or does it
  #8
Old 01-07-09, 10:05 PM
Dirk's Avatar
Administrator
Same procedure to enable it again. To the best of my knowledge it should not affect the airbag as it does not disable the seatbelt not buckled warning only the chime isnoff. My warning light stays on until I buckle it. Very happy now as I spend air of time in the car in our neighbourhood and often get out so it was becoming a pain.
  #9
Old 12-07-09, 03:56 PM
Pitzi-NC's Avatar
Pitzi-NC Pitzi-NC is offline
Member
Will this work on a 2006 WK Grand Cherokee?
__________________
2009 Chevrolet Lumina SS 6.0L MT
2006 BMW X5 3.0d Sports Pack
2007 Ford F250 XL 4x4 LWB P/U
  #10
Old 14-07-09, 09:27 PM
Dylo's Avatar
Dylo Dylo is offline
Member
It seems the seat belt ding ding noise is disabled the same on many other makes of vehicles too!
use or don't
  #11
Old 30-07-09, 06:43 PM
GVS GVS is offline
Member
Default thanX
dit werk op my 2007 GC
dankie tog
  #12
Old 30-07-09, 06:59 PM
Dirk's Avatar
Administrator
Nou soek ek nog die oplossing vir chime key in the ignition irritation!
__________________
2016 National GTG
  #13
Old 04-12-09, 07:37 AM
Chris_cross's Avatar
Chris_cross Chris_cross is offline
Member
This chime is giving me a heck of a lot of grey hairs....eish. Chrysler could figure out how damn annoying it is to hear this thing all day when the door is open?
  #14
Old 07-12-09, 03:33 PM
ignoramus ignoramus is offline
Member
Quote:
ja ASSEBLIEF is daar iemand wat 'n oplossing vir hierdie UITERS frustrerende aktiwiteit het ?
  #15
Old 04-01-10, 06:10 PM
CJ v H CJ v H is offline
Member
Great! Any luck on the 3.1 TD (WJ) ignition and seatbelt chime from someone?
  #16
Old 04-01-10, 07:41 PM
Dirk's Avatar
Administrator
Quote:
Have you tried the procedure at the top?
__________________
2016 National GTG
  #17
Old 09-02-10, 09:09 AM
Jeep Luvva's Avatar
Jeep Luvva Jeep Luvva is offline
Member
Quote:
Dirk,
I got this from a guy in the States, haven't had the opportunity to try it out though:
"wired a nintendo controller into the obdII port, up up down down left right left right start, no door chime."
The obvious way to stop the chime is to disconnect or remove your doors , problem with the disconnect is that it also disconnects your remote central locking.
Good luck finding a Nintendo controller.
__________________
Rich
VC - 4x4 Action Group
  #18
Old 23-03-10, 01:09 PM
Quiksilver's Avatar
Quiksilver Quiksilver is offline
Member
any new news on this?
Would love to turn the annoyance off...
  #19
Old 07-04-10, 02:49 PM
ipixel's Avatar
ipixel ipixel is offline
Member
Thanks, worked on my new, but used 2005 Jeep Grand Cherokee 3.0 CRD
  #20
Old 18-05-10, 09:12 AM
mcferreira mcferreira is offline
Member
Thumbs up Wow, it worked on my Cherokee 2.8 CRD 2003 model
I`ve been meaning for ages to visit a dealership to ask how do i kill this irritating noise. i just read your fix for the chime, tried it AND IT WORKED!!! you guys are the best, thanks very much.
  #21
Old 18-05-10, 09:00 PM
Dirk's Avatar
Administrator
Quote:
Our pleasure, now to return the favour please find us the key in ignition thingy!
__________________
2016 National GTG
  #22
Old 18-05-10, 09:07 PM
OFFROAD ADDICT's Avatar
OFFROAD ADDICT OFFROAD ADDICT is offline
ORA
I would just disconnect the chime from the system , reconnect when you sell.
__________________
ORA
Ian
  #23
Old 18-05-10, 09:16 PM
Morton Berg's Avatar
Morton Berg Morton Berg is offline
Member
Gosh and I thought a Korean was complex Been looking at Jeep prices and this has just thrown me off, totally. Guess I'll settle for a Mahindra
__________________
Morton the " BEAST " Berg
3 Skid plates;75mm lift;275/70/16 Maxxis MT's;Merrit 16Ērims;Maxe spots+ night breakers on all lights; Solace protection;TJM snorkel;TJM XGS shocks;TJM coils+Bellows; Maniac front & rear steel bumpers;Spare wheel and 3x Jerry can carriers;Rock sliders;Side awning;Front Runner roof rack; Dual batt system;Procool fridge/freezer;2xGarmin;clinometer;Twin free flow exhaust,Fini comp; ARB independent Airlockers F&B; Winch; Drawer Sys;50Lt Water tank;VHF&29Mhz(2)radios; 8x ss Fish road holders; Safety whip&flag.Future mods,Viper V10or Lex V8 Lumina 6lt
  #24
Old 14-06-10, 03:40 PM
Bomber Bomber is offline
Member
Quote:
Where is the chime on the WK? ... is this DIY?
__________________
Grand Cherokee Overland CRD 2007
  #25
Old 12-07-10, 10:37 PM
Dirk's Avatar
Administrator
Following a thread over on the JK-Forum, the chaps there identified that the switch the sounds the chime for door open key in ignition is in the latch itself, now which owner is going to open their door and get to the latch to figure out how to sort this out for once and for all?
__________________
2016 National GTG
  #26
Old 13-07-10, 08:12 AM
Apocalypse's Avatar
Apocalypse Apocalypse is offline
Member
Dirk, If I want mine off - which is only if I want to leave the radio on with the key in and the doors open - not often - I just unplug the door!!
Problem is that switch controls the interior light, radio off and a few other bits and pieces that all become disabled when it doesn't work. the computer desperatley needs to know if a door is open!!!!
of course - if you unplug the door, central locking and windows don't work...
It's a pain, but I've learnt to live with it I think... mostly...
I think you can also reprogram the radio to only go on or off manually - which means you never need to leave the key in... but then you might leave the radio on.. pain!!!
now mine is back - I'll have to check the manual for that!!!
__________________
Alex GP0221-WC
"the village scoundrel" - Uys
nobody will ever win the battle of the sexes. there is just too much fraternising with the enemy Henry Kissinger
Anyone who is capable of getting themselves made President should on no account be allowed to do the job.
Douglas Adams
those who can, do; those who can't, teach George Bernard Shaw
A business that makes nothing but money is a poor business.
Henry Ford
it is better to be irresponsible and right than to be responsible and wrong Winston Churchill
  #27
Old 13-07-10, 08:25 AM
ArrieMeyer ArrieMeyer is offline
Member
My Fortuner did not have a seat belt chime, but it had a little red flashing light that annoyed me in the bush when I really did not want the seat belt on. (On a public road it doesn't bother me, I always have the belt on anyway).
Here is how I solved it:
At the Dakkies in Zambesi they sell a little clip for the ladies' bags that will click into the seat belt slot, to prevent smash and grab losses. I just clipped it in and VOILA the light was dead. Alternatively go to a scrapyard and buy a seat belt clip.
I am not sure if it will work for all cars, but maybe it does.
  #28
Old 23-07-10, 08:59 AM
FDB's Avatar
FDB FDB is offline
Member
Sorry. Deleted my post because i see this thread is about seatbelt chimes.
  #29
Old 24-08-10, 09:56 AM
Megagustodon's Avatar
Megagustodon Megagustodon is offline
Member
Default WJ GC seatbelt chime disable
Do the following to disable the seatbelt chime on the WJ Grand Cherokee (from the 2004 Owners Manual):
NOTE:
The following steps must occur within the first 60 seconds of the ignition switch being turned to the ON or START position. The manufacturer does not recommend deactivating the Enhanced Warning System (BeltAlert).
fasten the driverís seat belt.
2. Start the engine, and wait for the Seat Belt Warning
Light to turn off.
and then re-buckle the driverís seat belt at least three
times, ending with the seat belt buckled.
4. Turn off the engine. A single chime will sound to
The Enhanced Warning System (BeltAlert) can be reactivated
by repeating this procedure.
__________________
2004 Jeep Grand Cherokee (WJ) 2.7HO CRD - Sadly sold
2012 Audi A3 Sportback 1.8T S-Tronic - Platkar
  #30
Old 26-08-10, 07:52 AM
Sako Sako is offline
Member
I noticed a few weeks ago that the volume of all the chimes on my JK was down to the extent that you really have to switch the radio off and put your ear close to the dash in order to hear it. Don't know how it happened....might be a loose connector or the buzzer is starting to pack up.
I miss that those sounds
__________________
2005 Discovery III V6S
  #31
Old 31-08-10, 11:29 AM
Arrie's Avatar
Arrie Arrie is offline
Member
I have done all this on my Commander XK and the seatbelt chime does not switch off...sigh.
__________________
I work off shore so I can Play OFF ROAD..lol
Jeep Commander 5.7 Hemmi. Ltd.
4" Lift and 33" BFG A/T
Superchip, Full 76mm free flow
Bumpers,Rocksliders, full house.
  #32
Old 18-10-10, 02:09 AM
dbor dbor is offline
Member
There is a solution to the key in ignition door chime
http://www.doubleblackoffroad.com/product.php?id=00022
  #33
Old 20-10-10, 03:45 PM
Jeep Luvva's Avatar
Member
Now to get pricing, hell I'm sure it's worth it.
__________________
Rich
  #34
Old 20-10-10, 06:54 PM
Dirk's Avatar
Administrator
Yip I will get pricing.
__________________
2016 National GTG
  #35
Old 20-10-10, 07:21 PM
Member
Based on todays rates 444 rand.
  #36
Old 19-01-11, 01:50 PM
SBSP's Avatar
SBSP SBSP is offline
Member
If you take out the chime and measure the resistance with a multimeter and replace it with a resistor of the same value it should also work, (Keeping the normal indicator functionality on the dash display)
I only have my TJ since last Thursday , and the buzzer anoye's the life out of me.
It litraly beeps on every action, putting it in park ,activating handbreak, doors ect ect
If i get a chnce this weekend im taking it out, will let you know how it went.
  #37
Old 21-01-11, 10:49 PM
Member
The tj chime is far simpler to the jk, the jk is quite complex. The problem is more apparent on Right Hand Drive models however. We have sold minimal chimebusters to Left Hand Drive Markets.
  #38
Old 13-10-11, 12:20 AM
TARRIAN TARRIAN is offline
Member
I have tried the seatbelt chime disbale procedure on a Nissan Qashqai and it worked!
Thanks!!
  #39
Old 13-10-11, 06:10 AM
Henris's Avatar
Henris Henris is offline
Commercial Member
I found a post on the LCCSA that disables the chime that will work on all vehicles.
Stuff the buzzer/bleeper full of silicone.
__________________
Let me be your link to anything property related. Buying, selling renting or letting.
I would love to make sure you are taken care of, the way you are supposed to be cared for.
Anywhere in the country.
  #40
Old 14-10-11, 09:52 PM
andre`
Guest
Posts: n/a
Just locate the correct wire for the door open switch and fit a micro switch on it. Then just flip the switch when the door is open for washing or radio playing with door open and switch it back on when finished. The wire colour can be found on the wiring diagram for the JK.
  #41
Old 14-10-11, 10:59 PM
Dirk's Avatar
Administrator
Now can somebody please tell us where this buzzer is!
__________________
2016 National GTG
  #42
Old 15-10-11, 06:30 AM
Henris's Avatar
Commercial Member
__________________
  #43
Old 28-01-12, 11:51 AM
Clint_Hemi's Avatar
Clint_Hemi Clint_Hemi is offline
Member
There's a simple fix for the seat belt buzzer that works on any car. Go to a scrapyard (or dealership if you have too much money), buy a spare seat belt buckle, and plug that in when you're in the bush.
  #44
Old 13-02-12, 09:04 AM
Bundu Boy's Avatar
Bundu Boy Bundu Boy is offline
Member
Just tried it on my 2005 KJ and it worked, now when I'm in the bush I don't have to strap the seatbelt around the back of my chair to stop the beep.
__________________
2012 Fortuner 4.0 V6 4x4
My ex with a drinking problem
2005 Jeep Cherokee KJ 3.7L
  #45
Old 05-03-12, 01:34 PM
Mouritz Mouritz is offline
Member
just tried it on my 2012 Rubicon, it worked like a charm. went to the dealer for some other stuff, had them login the system to activate door locking. and the system showed that the seatbelt chime was off.
I then confirmed that it has no effect on the airbags.
  #46
Old 05-03-12, 01:36 PM
Member
for the door chime, they cannot deactivate it, but the advice was use a pen. as the switch is in the door lock, just push the latch to close with a pen and no more chime. remember to open latch before closing door..
  #47
Old 03-06-12, 10:36 PM
LourensL's Avatar
LourensL LourensL is offline
Member
Quote:
Thanks!!
I'm gonna try it tomorrow on my 2005 WK
  #48
Old 06-06-12, 04:12 PM
LourensL's Avatar
Member
And it works like a charm! Now to disable that pesky engine light..
  #49
Old 12-06-12, 07:07 PM
ToyX4 ToyX4 is offline
Account removed
Seatbelt chime disabled on my Commander. Thank goodness
  #50
Old 29-08-12, 03:13 PM
Tadek Tadek is offline
Member
I think it's all programmable. At my last service I asked for the seatbelt warning to be disabled and presto..... I mean so I can drive off-road with setbelts off. It just chimes when you start the engine. However, I would think that all these features can be turned on or off, provided the dealer knows his stuff.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Chimes mud play time NEON DEON Calender & Events 2 27-01-11 01:16 PM
Good CHIMES & Offroad Recue 6 March 2010 JNel 4x4 Trails / Routes / Clubs 10 08-03-10 02:33 PM
Camp chimes -xmas party gtg proposal NEON DEON 4x4 Trails / Routes / Clubs 33 15-11-09 09:00 PM
Template-Modifications by TMS
