logo
Go Back   4x4 Community Forum > All about vehicles > Vehicle & Technical Chat - General > Mahindra
4x4Community
Reply
Thread Tools Display Modes
  #1
Old 25-10-10, 07:27 AM
Duka's Avatar
Duka Duka is offline
Member
Default Shocks
Fellow Mahindra fans.
My 2.6 Td SUV needs new shocks. What would you recommend? Approximate price? For front and rear.
  #2
Old 25-10-10, 08:00 AM
Wise one's Avatar
Wise one Wise one is offline
Member
Talking Shocks
It all depends on what your needs are and how far you are prepared to stretch your budget. I have just fitted Monroe Gas Magnums to my Defender, R425 each from Midas, am very satisfied.
  #3
Old 25-10-10, 08:11 AM
Duka's Avatar
Member
Thanks Wise One
I suspected prices to be in the region of R500. I do quite a lot of driving on some bad gravel roads, also heard from other guys that the Monroe's are quite good! Apparently I should stay clear of Gabriels.
  #4
Old 25-10-10, 08:14 AM
SorentoMB's Avatar
SorentoMB SorentoMB is offline
Member
Hi Duka,
I replaced my front shocks with Monroe original gas adjust shocks and the rears with Monroe gas magnums. The gas magnums are a bit thicker than the OEM ones, I had to take of a mm or 2 on the shock mounts. I am very happy with them. +- R400 each.
  #5
Old 26-10-10, 03:40 PM
fransv fransv is offline
Member
Hi Scorpio Turbo
Do you perhaps know the part numbers for the Monroe front and rear shocks.
I replace shocks some time ago and the Tyre dealers charge me a lot- and that for gas Gabriels!
  #6
Old 26-10-10, 03:49 PM
SorentoMB's Avatar
Member
Hi Frans,
I'll have to find the invoice to check the part numbers. I'll have to get back to you.
  #7
Old 27-10-10, 11:28 AM
Member
Thanks!
  #8
Old 28-10-10, 08:53 AM
Mario.za Mario.za is offline
Member
Hey Duka,
Presently Monroe only has the pickup shocks in stock. I spoke to the sales office yesterday and the shipment for the suv is on its way. Stock should be available from mid November 2010. part nr R1663 and R1664
  #9
Old 28-10-10, 04:24 PM
Jerrycan Jerrycan is offline
Member
Default Monroe Shocks SUV 2.6TD
Hey Duka,
I fittled MONROES last month (Sept) just before I went up to the Richtersveld. I fitted the standard Monroe Original Gas Shocks to the FRONT only. (one of the old ones was leaking at 79,500km). The Part Number was R2721 and it is a very easy quick fit of same. Literally only takes a few minutes. I can honestly say, I did in fact notice a nice difference for the couple of days before I set off...much better handling through corners. We bounced many a rut and bump enroute to the Richtersveld on the back roads (very corrugated) and then drove around there for some 8 days. Very Happy with same. I got mine through a 4x4 outlet here called G-Tech who also made my steel sump and front diff guard. Can also say I don't notice any difference now...but then one gets used to the improvement. Next will have to think about the rears. Cheers.
  #10
Old 16-11-10, 10:16 AM
Member
Monroe has stock:
Part nr R2773 and R2775 for Scorpio 4x2 SUV
Phone your local Midas to order.
  #11
Old 16-11-10, 11:54 AM
Duka's Avatar
Member
Hi Guys
Thanks for all the info.
Was in Thabazimbi for work and saw that my tires was really worn as well. Fitted 4 brand new tires 245/70 R16 and then the shocks.... There was no shocks available in Thabazimbi for the duration that I was there, but luckely a very nice Chap at Autozone put in a lot of effort and got hold of 2 Monroe heavy duty gas shocks for the front and 2 Gabriel Safari gas shocks for the rear. Especially the Gabriels were much thicker and biefier than the original Monroes fitted. All went well with the fitment of the tires and the shocks and it feels like I am driving a brand new vehicle! The shocks especially made a huge difference!
  #12
Old 16-11-10, 11:59 AM
Navigator's Avatar
Navigator Navigator is offline
Commercial Member
Please give us the part numbers of the Gabriel`s and Monroe`s
__________________
SUSPENSION FOR THE FUTURE
Cobus Bohmer - 071 641 7947
www.amadaxtreme.co.za
cobus@amadaxtreme.co.za
Rudi Grobbelaar - 061 609 7312
rudi@amadaxtreme.co.za
  #13
Old 16-11-10, 12:11 PM
Duka's Avatar
Member
Here is the part numbers as on the invoice from Autozone:
Gabriels: GAB.G56116
Monroes: MNR.GT2028
  #14
Old 23-10-12, 01:44 PM
StefanDB's Avatar
StefanDB StefanDB is offline
Member
What is the difference between the Monroe Gas Magnum/Adventure and Old Man Emu shocks? Or is it all just the same thing?
__________________
  #15
Old 23-10-12, 01:58 PM
SorentoMB's Avatar
Member
The price...Just kiding, the OME shocks are probably much higher quality and can take a bigger beating. Can the OME shocks not also be refurbished?
__________________
  #16
Old 23-10-12, 02:08 PM
StefanDB's Avatar
Member
Quote:
Even on the Thar? My shocks seems to be very dicey.
__________________
  #17
Old 23-10-12, 02:38 PM
Navigator's Avatar
Commercial Member
Quote:
I took my shocks out over the weekend, just to inspect. The rear bushes show serious wear, but both front and rear shocks are very, very weak.. not very impressed!!
__________________
  #18
Old 23-10-12, 03:02 PM
StefanDB's Avatar
Member
So what would you recommend as a replacement shock then?
__________________
  #19
Old 23-10-12, 03:15 PM
Navigator's Avatar
Commercial Member
All I can say is watch this space... should have an answer soon...
__________________
  #20
Old 24-10-12, 07:05 AM
juriedp's Avatar
juriedp juriedp is offline
Member
Hi Guys,
Yup, been looking at my Thar, those shocks of mine must have gone to heaven. If all goes to plan next year March I will bring back some decent off-road shock for my Thar from overseas. Till then normal replacements would need to do.
__________________
Jurie
Call Sign: E01
Wilma: 2011
Mahindra Thar 4X4
2.5 CRDe now with MAXXIS BIGHORN 764's 245/75R16's
Ruby: 2009 Jeep Rubicon Unlimited now with Goodyear Wrangler AT/SA 265/65 R17's
EX:
2012 Mahindra XUV 500 W8 4X2 2.2 mHawk now with Goodyear Wrangler AT/SA 235/65 R17's
  #21
Old 24-10-12, 09:25 AM
StefanDB's Avatar
Member
I have another question, which is partly related. The torsion bar in the front suspicion, can that be replaced by shocks and springs or would it not be viable.
__________________
  #22
Old 24-10-12, 10:01 AM
SorentoMB's Avatar
Member
Only the 4x2 can have coil springs in the front. On the 4x4 the drive-shafts runs were the coils should go. Coil over shocks might work if there is enough space, but their coils will only assist the torsion bar, not replace it.
__________________
  #23
Old 24-10-12, 04:17 PM
Navigator's Avatar
Commercial Member
I had Camils on my Bolero, yes they assist the torsion bars but rubbish damping shocks, not much better than the std pathetic shocks.
__________________
  #24
Old 01-11-12, 06:17 AM
K. Meyer's Avatar
K. Meyer K. Meyer is offline
Member
Do you know if the TJM shocks for the Thar is available in SA:
Parts-
Shocks-Front Mahindra Thar TJM 650GE1320
Shocks-Rear Mahindra Thar TJM 650GE2320
  #25
Old 01-11-12, 07:02 AM
StefanDB's Avatar
Member
For TJM I think you need to contact LA Sport.
__________________
  #26
Old 01-11-12, 07:06 AM
StefanDB's Avatar
Member
What woud be the recommended replacement on my Thar then?
Camil in front.
Monroes 4X4 Gas Manguns or Gabriel Safari HDP Gas the back?
__________________
  #27
Old 01-11-12, 07:23 AM
Navigator's Avatar
Commercial Member
I had Camils in my Bolero, yes it does help to lift the front suspension and release tension on the torsion bars, but the shocks damping capabilities is poor, does not get close to TJM's or any good off road shock.
__________________
  #28
Old 01-11-12, 07:28 AM
StefanDB's Avatar
Member
Does anybody have part numbers for the shocks for the Thar for various makes of shocks?
__________________
  #29
Old 01-11-12, 07:42 AM
StefanDB's Avatar
Member
Wat gaan 'n stel TJM's voor my kos?
__________________
  #30
Old 01-11-12, 08:17 AM
StefanDB's Avatar
Member
Nou net met die mense by LA Sport gepraat. HUlle se die voorste TJM shocks is te dik om te pas en dat die control arm in die pad is. Het enige van julel al die TJMs opgesit op julle Thar?
Die ouens by Lombaard Bande se ek kan net Shocks deur die agente kry. Ek is seker daar moet 'n shock wees wat sal pas.
__________________
  #31
Old 01-11-12, 08:25 AM
juriedp's Avatar
Member
Hi Stefan,
Nee nog nie, maar ek sal jou posts dophou omdat ek nie ver agter jou is met die nie. Dink my shocks is nie meer nie.
Hou ons op hoogte asb.
Groete,
__________________
Jurie
Call Sign: E01
Wilma: 2011
Mahindra Thar 4X4
EX:
  #32
Old 01-11-12, 08:46 AM
StefanDB's Avatar
Member
Is die Thar se onderstel nie net maar 'n short wheel base Bolero nie?
__________________
  #33
Old 01-11-12, 03:49 PM
SorentoMB's Avatar
Member
Haal die shocks uit en gaan na Midas of Autozone, hulle kan dit meet en match met ander karre se shocks. Ek het bv toyota bakie spec shocks op my Scorpio.
__________________
  #34
Old 01-11-12, 06:37 PM
Navigator's Avatar
Commercial Member
Ek moet gaan soek, ek het die Gabriel part nommers erens
__________________
  #35
Old 17-11-12, 08:52 AM
rudo rudo is offline
Member
Hallo almal.
Enige aanbeveling vir Scorpio 4x4 At 2010 model: Monroe, TJM? Part nommers asb.
Dankie
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
The West Coast trip & the shocks....... Thys Willemse Land Rover 2 07-11-13 09:36 PM
Checking your vehicle's shocks Big Hilux Vehicle & Technical Chat - General 11 22-10-12 01:40 PM
Rancho RS9000 Shocks Dirk Vehicle & Technical Chat - General 20 19-02-08 11:16 AM
Bilsteins for Gen3 from Shocks & Springs Gerrit Loubser Mitsubishi 15 18-10-07 10:34 PM
Template-Modifications by TMS
